Time Before: 0.02235 seconds
Time After: 0.03112 seconds
Time Taken: 0.00877 seconds
Time Before: 0.03125 seconds
Time After: 0.03176 seconds
Time Before: 0.03203 seconds
Time After: 0.03215 seconds
Time Before: 0.03289 seconds
Time After: 0.03508 seconds
Time Taken: 0.00219 seconds
Time Before: 0.03222 seconds
Time After: 0.04041 seconds
Time Taken: 0.00819 seconds
Time Before: 0.05053 seconds
Time After: 0.05096 seconds
Time Before: 0.05384 seconds
Time After: 0.05502 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04971 seconds
Time After: 0.05529 seconds
Time Taken: 0.00558 seconds
Time Before: 0.09772 seconds
Time After: 0.09788 seconds
Time Before: 0.33233 seconds
Time After: 0.33374 seconds
End call of global.php: 0.33599710464478
Time Before: 0.34403 seconds
Time After: 0.34430 seconds
Time Before: 0.34679 seconds
Time After: 0.34971 seconds
Time Taken: 0.00292 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=51959', badlocation = 1
WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.36971 seconds
Time After: 0.37016 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.36848187446594 seconds with 9 queries, spending 0.0096328258514404 doing MySQL queries and 0.3588490486145 doing PHP things.
