Time Before: 0.00361 seconds
Time After: 0.00450 seconds
Time Taken: 0.00089 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00457 seconds
Time After: 0.00504 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00528 seconds
Time After: 0.00550 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00630 seconds
Time After: 0.00836 seconds
Time Taken: 0.00206 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00555 seconds
Time After: 0.01278 seconds
Time Taken: 0.00723 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01554 seconds
Time After: 0.01596 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01853 seconds
Time After: 0.01983 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01482 seconds
Time After: 0.02000 seconds
Time Taken: 0.00518 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.02608 seconds
Time After: 0.02622 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03355 seconds
Time After: 0.03482 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.04290 seconds
Time After: 0.04306 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.04515 seconds
Time After: 0.04658 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1772934280, location = '/forums/private.php?do=newpm&explain=1&u=52067', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.06193 seconds
Time After: 0.06240 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
