Time Before: 0.00164 seconds
Time After: 0.00245 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00255 seconds
Time After: 0.00319 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00344 seconds
Time After: 0.00363 seconds
Time Before: 0.00454 seconds
Time After: 0.00717 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00367 seconds
Time After: 0.01187 seconds
Time Taken: 0.00820 seconds
Time Before: 0.01455 seconds
Time After: 0.01502 seconds
Time Before: 0.01840 seconds
Time After: 0.01967 seconds
Time Before: 0.01371 seconds
Time After: 0.01994 seconds
Time Taken: 0.00623 seconds
Time Before: 0.02640 seconds
Time After: 0.02655 seconds
Time Before: 0.02887 seconds
Time After: 0.03014 seconds
Time Before: 0.03417 seconds
Time After: 0.03431 seconds
Time Before: 0.03638 seconds
Time After: 0.03788 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=52190' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.05157 seconds
Time After: 0.05188 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
