Time Before: 0.02095 seconds
Time After: 0.02785 seconds
Time Taken: 0.00690 seconds
Time Before: 0.02795 seconds
Time After: 0.02834 seconds
Time Before: 0.02862 seconds
Time After: 0.02877 seconds
Time Before: 0.02955 seconds
Time After: 0.03154 seconds
Time Taken: 0.00199 seconds
Time Before: 0.02884 seconds
Time After: 0.03589 seconds
Time Taken: 0.00705 seconds
Time Before: 0.04320 seconds
Time After: 0.04357 seconds
Time Before: 0.04624 seconds
Time After: 0.04790 seconds
Time Taken: 0.00165 seconds
Time Before: 0.04242 seconds
Time After: 0.04813 seconds
Time Taken: 0.00571 seconds
Time Before: 0.08228 seconds
Time After: 0.08248 seconds
Time Before: 0.09903 seconds
Time After: 0.10032 seconds
End call of global.php: 0.10316610336304
Time Before: 0.11186 seconds
Time After: 0.11203 seconds
Time Before: 0.11466 seconds
Time After: 0.11614 seconds
SET lastactivity = 1776614971, location = '/forums/private.php?do=newpm&explain=1&u=52207', badlocation = 1
Time Before: 0.13541 seconds
Time After: 0.13579 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.13437414169312 seconds with 9 queries, spending 0.0080802440643311 doing MySQL queries and 0.12629389762878 doing PHP things.
