Time Before: 0.00130 seconds
Time After: 0.00176 seconds
Time Before: 0.00183 seconds
Time After: 0.00221 seconds
Time Before: 0.00243 seconds
Time After: 0.00257 seconds
Time Before: 0.00348 seconds
Time After: 0.00743 seconds
Time Taken: 0.00394 seconds
Time Before: 0.00266 seconds
Time After: 0.01223 seconds
Time Taken: 0.00957 seconds
Time Before: 0.01439 seconds
Time After: 0.01487 seconds
Time Before: 0.01778 seconds
Time After: 0.01905 seconds
Time Before: 0.01369 seconds
Time After: 0.01933 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02554 seconds
Time After: 0.02575 seconds
Time Before: 0.02777 seconds
Time After: 0.02903 seconds
Time Before: 0.03366 seconds
Time After: 0.03387 seconds
Time Before: 0.03632 seconds
Time After: 0.03788 seconds
Time Taken: 0.00157 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=52265', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05359 seconds
Time After: 0.05394 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
