Time Before: 0.00184 seconds
Time After: 0.00254 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00264 seconds
Time After: 0.00312 seconds
Time Before: 0.00340 seconds
Time After: 0.00360 seconds
Time Before: 0.00451 seconds
Time After: 0.00697 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00367 seconds
Time After: 0.01225 seconds
Time Taken: 0.00857 seconds
Time Before: 0.01427 seconds
Time After: 0.01476 seconds
Time Before: 0.01737 seconds
Time After: 0.01861 seconds
Time Before: 0.01353 seconds
Time After: 0.01879 seconds
Time Taken: 0.00525 seconds
Time Before: 0.02389 seconds
Time After: 0.02409 seconds
Time Before: 0.02605 seconds
Time After: 0.02728 seconds
Time Before: 0.03021 seconds
Time After: 0.03043 seconds
Time Before: 0.03238 seconds
Time After: 0.03385 seconds
UPDATE session SET lastactivity = 1788973228, location = '/forums/private.php?do=newpm&explain=1&u=52437', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04625 seconds
Time After: 0.04662 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
