Time Before: 0.01058 seconds
Time After: 0.01516 seconds
Time Taken: 0.00458 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.01528 seconds
Time After: 0.01569 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.01591 seconds
Time After: 0.01602 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01682 seconds
Time After: 0.01912 seconds
Time Taken: 0.00231 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.01608 seconds
Time After: 0.02341 seconds
Time Taken: 0.00733 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.03120 seconds
Time After: 0.03160 seconds
Time Before: 0.03443 seconds
Time After: 0.03568 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03049 seconds
Time After: 0.03589 seconds
Time Taken: 0.00540 seconds
Memory After: 2,261.703 KB
Time Before: 0.06180 seconds
Time After: 0.06200 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.07686 seconds
Time After: 0.07820 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.08598 seconds
Time After: 0.08615 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.08821 seconds
Time After: 0.08997 seconds
Time Taken: 0.00176 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=52589' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.10493 seconds
Time After: 0.10524 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
