Time Before: 0.02231 seconds
Time After: 0.03052 seconds
Time Taken: 0.00821 seconds
Time Before: 0.03061 seconds
Time After: 0.03105 seconds
Time Before: 0.03134 seconds
Time After: 0.03153 seconds
Time Before: 0.03223 seconds
Time After: 0.03475 seconds
Time Taken: 0.00253 seconds
Time Before: 0.03158 seconds
Time After: 0.03924 seconds
Time Taken: 0.00766 seconds
Time Before: 0.04783 seconds
Time After: 0.04824 seconds
Time Before: 0.05062 seconds
Time After: 0.05183 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04714 seconds
Time After: 0.05212 seconds
Time Taken: 0.00498 seconds
Memory After: 2,261.836 KB
Time Before: 0.10375 seconds
Time After: 0.10390 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.36725 seconds
Time After: 0.36851 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.37068796157837
Time Before: 0.37546 seconds
Time After: 0.37563 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.37868 seconds
Time After: 0.38015 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789109031, location = '/forums/private.php?do=newpm&explain=1&u=52707', badlocation = 1
Time Before: 0.39951 seconds
Time After: 0.39995 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.39839291572571 seconds with 9 queries, spending 0.0082602500915527 doing MySQL queries and 0.39013266563416 doing PHP things.
