Time Before: 0.02019 seconds
Time After: 0.02569 seconds
Time Taken: 0.00551 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02580 seconds
Time After: 0.02623 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02646 seconds
Time After: 0.02659 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02740 seconds
Time After: 0.02952 seconds
Time Taken: 0.00212 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02664 seconds
Time After: 0.03469 seconds
Time Taken: 0.00805 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04176 seconds
Time After: 0.04217 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04478 seconds
Time After: 0.04596 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04104 seconds
Time After: 0.04615 seconds
Time Taken: 0.00511 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.07907 seconds
Time After: 0.07921 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.13075 seconds
Time After: 0.13245 seconds
Time Taken: 0.00169 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.13492798805237
Time Before: 0.16649 seconds
Time After: 0.16667 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.17129 seconds
Time After: 0.17275 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772882238, location = '/forums/private.php?do=newpm&explain=1&u=52721', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.20253 seconds
Time After: 0.20295 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.20149397850037 seconds with 9 queries, spending 0.0081698894500732 doing MySQL queries and 0.19332408905029 doing PHP things.
