Time Before: 0.00143 seconds
Time After: 0.00197 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00204 seconds
Time After: 0.00239 seconds
Time Before: 0.00272 seconds
Time After: 0.00287 seconds
Time Before: 0.00356 seconds
Time After: 0.00594 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00292 seconds
Time After: 0.00930 seconds
Time Taken: 0.00638 seconds
Time Before: 0.01110 seconds
Time After: 0.01145 seconds
Time Before: 0.01418 seconds
Time After: 0.01587 seconds
Time Taken: 0.00169 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01050 seconds
Time After: 0.01604 seconds
Time Taken: 0.00553 seconds
Memory After: 2,261.836 KB
Time Before: 0.02145 seconds
Time After: 0.02160 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02376 seconds
Time After: 0.02500 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.02669095993042
Time Before: 0.02804 seconds
Time After: 0.02819 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03024 seconds
Time After: 0.03170 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789111462, location = '/forums/private.php?do=newpm&explain=1&u=5279'
Time Before: 0.04391 seconds
Time After: 0.04419 seconds
Memory Before: 4,287.586 KB
Memory After: 4,287.805 KB
Page generated in 0.043008089065552 seconds with 9 queries, spending 0.0082178115844727 doing MySQL queries and 0.034790277481079 doing PHP things.
