Time Before: 0.00152 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00248 seconds
Time Before: 0.00270 seconds
Time After: 0.00284 seconds
Time Before: 0.00357 seconds
Time After: 0.00647 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00289 seconds
Time After: 0.00985 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01178 seconds
Time After: 0.01217 seconds
Time Before: 0.01369 seconds
Time After: 0.01504 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01101 seconds
Time After: 0.01528 seconds
Time Taken: 0.00427 seconds
Time Before: 0.02090 seconds
Time After: 0.02105 seconds
Time Before: 0.02325 seconds
Time After: 0.02464 seconds
Time Taken: 0.00140 seconds
Time Before: 0.02792 seconds
Time After: 0.02815 seconds
Time Before: 0.03082 seconds
Time After: 0.03236 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=52841' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04589 seconds
Time After: 0.04618 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
