Time Before: 0.03334 seconds
Time After: 0.04478 seconds
Time Taken: 0.01144 seconds
Time Before: 0.04489 seconds
Time After: 0.04537 seconds
Time Before: 0.04566 seconds
Time After: 0.04578 seconds
Time Before: 0.04659 seconds
Time After: 0.04880 seconds
Time Taken: 0.00221 seconds
Time Before: 0.04584 seconds
Time After: 0.05354 seconds
Time Taken: 0.00770 seconds
Time Before: 0.06591 seconds
Time After: 0.06632 seconds
Time Before: 0.06803 seconds
Time After: 0.06925 seconds
Time Before: 0.06519 seconds
Time After: 0.06944 seconds
Time Taken: 0.00426 seconds
Time Before: 0.12180 seconds
Time After: 0.12193 seconds
Time Before: 0.15161 seconds
Time After: 0.15286 seconds
Time Before: 0.16712 seconds
Time After: 0.16728 seconds
Time Before: 0.17008 seconds
Time After: 0.17179 seconds
Time Taken: 0.00171 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=52884', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.19227 seconds
Time After: 0.19252 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
