Time Before: 0.00216 seconds
Time After: 0.00293 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00300 seconds
Time After: 0.00359 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00385 seconds
Time After: 0.00396 seconds
Time Before: 0.00464 seconds
Time After: 0.00704 seconds
Time Taken: 0.00240 seconds
Time Before: 0.00401 seconds
Time After: 0.01045 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01244 seconds
Time After: 0.01284 seconds
Time Before: 0.01427 seconds
Time After: 0.01547 seconds
Time Before: 0.01179 seconds
Time After: 0.01565 seconds
Time Taken: 0.00385 seconds
Time Before: 0.02064 seconds
Time After: 0.02084 seconds
Time Before: 0.02311 seconds
Time After: 0.02446 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.026189088821411
Time Before: 0.02739 seconds
Time After: 0.02752 seconds
Time Before: 0.02963 seconds
Time After: 0.03108 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=52901'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04420 seconds
Time After: 0.04452 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.043308973312378 seconds with 9 queries, spending 0.0081636905670166 doing MySQL queries and 0.035145282745361 doing PHP things.
