Time Before: 0.02331 seconds
Time After: 0.03130 seconds
Time Taken: 0.00799 seconds
Time Before: 0.03138 seconds
Time After: 0.03185 seconds
Time Before: 0.03209 seconds
Time After: 0.03222 seconds
Time Before: 0.03304 seconds
Time After: 0.03557 seconds
Time Taken: 0.00254 seconds
Time Before: 0.03229 seconds
Time After: 0.03966 seconds
Time Taken: 0.00737 seconds
Time Before: 0.05013 seconds
Time After: 0.05050 seconds
Time Before: 0.05311 seconds
Time After: 0.05433 seconds
Time Before: 0.04937 seconds
Time After: 0.05458 seconds
Time Taken: 0.00521 seconds
Time Before: 0.10148 seconds
Time After: 0.10165 seconds
Time Before: 0.12718 seconds
Time After: 0.12839 seconds
End call of global.php: 0.13052701950073
Time Before: 0.14357 seconds
Time After: 0.14372 seconds
Time Before: 0.14626 seconds
Time After: 0.14767 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=52919', badlocation = 1
Time Before: 0.17077 seconds
Time After: 0.17108 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.16962385177612 seconds with 9 queries, spending 0.0079727172851562 doing MySQL queries and 0.16165113449097 doing PHP things.
