Time Before: 0.00136 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00226 seconds
Time Before: 0.00245 seconds
Time After: 0.00259 seconds
Time Before: 0.00332 seconds
Time After: 0.00550 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00263 seconds
Time After: 0.00885 seconds
Time Taken: 0.00622 seconds
Time Before: 0.01088 seconds
Time After: 0.01125 seconds
Time Before: 0.01427 seconds
Time After: 0.01547 seconds
Time Before: 0.01019 seconds
Time After: 0.01566 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02053 seconds
Time After: 0.02066 seconds
Time Before: 0.02246 seconds
Time After: 0.02368 seconds
Time Before: 0.02670 seconds
Time After: 0.02684 seconds
Time Before: 0.02884 seconds
Time After: 0.03027 seconds
UPDATE session SET lastactivity = 1780632996, location = '/forums/private.php?do=newpm&explain=1&u=52951', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04379 seconds
Time After: 0.04409 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
