Time Before: 0.02454 seconds
Time After: 0.02887 seconds
Time Taken: 0.00433 seconds
Time Before: 0.02897 seconds
Time After: 0.02984 seconds
Time Taken: 0.00087 seconds
Time Before: 0.03018 seconds
Time After: 0.03039 seconds
Time Before: 0.03143 seconds
Time After: 0.03367 seconds
Time Taken: 0.00224 seconds
Time Before: 0.03047 seconds
Time After: 0.03945 seconds
Time Taken: 0.00898 seconds
Time Before: 0.04747 seconds
Time After: 0.04797 seconds
Time Before: 0.04962 seconds
Time After: 0.05083 seconds
Time Before: 0.04674 seconds
Time After: 0.05107 seconds
Time Before: 0.08762 seconds
Time After: 0.08777 seconds
Time Before: 0.09902 seconds
Time After: 0.10031 seconds
Time Before: 0.10952 seconds
Time After: 0.10967 seconds
Time Before: 0.11303 seconds
Time After: 0.11481 seconds
Time Taken: 0.00178 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=52953', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.13395 seconds
Time After: 0.13426 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
