Time Before: 0.00178 seconds
Time After: 0.00231 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00239 seconds
Time After: 0.00270 seconds
Time Before: 0.00287 seconds
Time After: 0.00328 seconds
Time Before: 0.00414 seconds
Time After: 0.00628 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00333 seconds
Time After: 0.01126 seconds
Time Taken: 0.00793 seconds
Time Before: 0.01361 seconds
Time After: 0.01404 seconds
Time Before: 0.01715 seconds
Time After: 0.01836 seconds
Time Before: 0.01301 seconds
Time After: 0.01861 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02519 seconds
Time After: 0.02533 seconds
Time Before: 0.02711 seconds
Time After: 0.02838 seconds
Time Before: 0.03274 seconds
Time After: 0.03288 seconds
Time Before: 0.03599 seconds
Time After: 0.03748 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=53025', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05112 seconds
Time After: 0.05147 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
