Time Before: 0.00207 seconds
Time After: 0.00277 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00287 seconds
Time After: 0.00331 seconds
Time Before: 0.00359 seconds
Time After: 0.00372 seconds
Time Before: 0.00456 seconds
Time After: 0.00924 seconds
Time Taken: 0.00469 seconds
Time Before: 0.00379 seconds
Time After: 0.01447 seconds
Time Taken: 0.01068 seconds
Time Before: 0.01697 seconds
Time After: 0.01742 seconds
Time Before: 0.01992 seconds
Time After: 0.02114 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01601 seconds
Time After: 0.02138 seconds
Time Taken: 0.00537 seconds
Memory After: 2,261.836 KB
Time Before: 0.02683 seconds
Time After: 0.02702 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02921 seconds
Time After: 0.03046 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.032227039337158
Time Before: 0.03342 seconds
Time After: 0.03361 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03634 seconds
Time After: 0.03915 seconds
Time Taken: 0.00280 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788982656, location = '/forums/private.php?do=newpm&explain=1&u=53070', badlocation = 1
Time Before: 0.05518 seconds
Time After: 0.05547 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.054092884063721 seconds with 9 queries, spending 0.011656284332275 doing MySQL queries and 0.042436599731445 doing PHP things.
