Time Before: 0.01588 seconds
Time After: 0.02031 seconds
Time Taken: 0.00443 seconds
Time Before: 0.02042 seconds
Time After: 0.02094 seconds
Time Before: 0.02121 seconds
Time After: 0.02136 seconds
Time Before: 0.02226 seconds
Time After: 0.02471 seconds
Time Taken: 0.00245 seconds
Time Before: 0.02144 seconds
Time After: 0.02879 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03520 seconds
Time After: 0.03577 seconds
Time Taken: 0.00058 seconds
Time Before: 0.03908 seconds
Time After: 0.04053 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03417 seconds
Time After: 0.04080 seconds
Time Taken: 0.00663 seconds
Memory After: 2,261.719 KB
Time Before: 0.05982 seconds
Time After: 0.05995 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06996 seconds
Time After: 0.07183 seconds
Time Taken: 0.00188 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.074087858200073
Time Before: 0.07699 seconds
Time After: 0.07715 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07997 seconds
Time After: 0.08143 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=53095', badlocation = 1
Time Before: 0.10273 seconds
Time After: 0.10306 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.10131978988647 seconds with 9 queries, spending 0.0090985298156738 doing MySQL queries and 0.092221260070801 doing PHP things.
