Time Before: 0.00335 seconds
Time After: 0.00454 seconds
Time Before: 0.00464 seconds
Time After: 0.00508 seconds
Time Before: 0.00541 seconds
Time After: 0.00555 seconds
Time Before: 0.00668 seconds
Time After: 0.01061 seconds
Time Taken: 0.00393 seconds
Time Before: 0.00565 seconds
Time After: 0.01404 seconds
Time Taken: 0.00839 seconds
Time Before: 0.01632 seconds
Time After: 0.01693 seconds
Time Taken: 0.00061 seconds
Time Before: 0.01996 seconds
Time After: 0.02115 seconds
Time Before: 0.01570 seconds
Time After: 0.02139 seconds
Time Taken: 0.00569 seconds
Time Before: 0.02804 seconds
Time After: 0.02820 seconds
Time Before: 0.03016 seconds
Time After: 0.03142 seconds
Time Before: 0.03622 seconds
Time After: 0.03637 seconds
Time Before: 0.03864 seconds
Time After: 0.04012 seconds
UPDATE session SET lastactivity = 1789026320, location = '/forums/private.php?do=newpm&explain=1&u=53127', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05348 seconds
Time After: 0.05373 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
