Time Before: 0.00152 seconds
Time After: 0.00203 seconds
Time Before: 0.00209 seconds
Time After: 0.00255 seconds
Time Before: 0.00277 seconds
Time After: 0.00288 seconds
Time Before: 0.00376 seconds
Time After: 0.00671 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00297 seconds
Time After: 0.01143 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01345 seconds
Time After: 0.01372 seconds
Time Before: 0.01610 seconds
Time After: 0.01738 seconds
Time Before: 0.01282 seconds
Time After: 0.01755 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02282 seconds
Time After: 0.02304 seconds
Time Before: 0.02550 seconds
Time After: 0.02679 seconds
Time Before: 0.03035 seconds
Time After: 0.03053 seconds
Time Before: 0.03256 seconds
Time After: 0.03414 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=53149' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04783 seconds
Time After: 0.04814 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
