Time Before: 0.02386 seconds
Time After: 0.03493 seconds
Time Taken: 0.01108 seconds
Time Before: 0.03504 seconds
Time After: 0.03543 seconds
Time Before: 0.03566 seconds
Time After: 0.03580 seconds
Time Before: 0.03676 seconds
Time After: 0.03923 seconds
Time Taken: 0.00246 seconds
Time Before: 0.03586 seconds
Time After: 0.04329 seconds
Time Taken: 0.00744 seconds
Time Before: 0.05409 seconds
Time After: 0.05449 seconds
Time Before: 0.05616 seconds
Time After: 0.05735 seconds
Time Before: 0.05339 seconds
Time After: 0.05757 seconds
Time Taken: 0.00417 seconds
Time Before: 0.09771 seconds
Time After: 0.09785 seconds
Time Before: 0.11989 seconds
Time After: 0.12112 seconds
Time Before: 0.13142 seconds
Time After: 0.13158 seconds
Time Before: 0.13400 seconds
Time After: 0.13560 seconds
Time Taken: 0.00160 seconds
UPDATE session SET lastactivity = 1785301989, location = '/forums/private.php?do=newpm&explain=1&u=53150' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.15004 seconds
Time After: 0.15032 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
