Time Before: 0.00464 seconds
Time After: 0.00804 seconds
Time Taken: 0.00340 seconds
Memory Before: 532.906 KB
Memory After: 558.023 KB
Time Before: 0.00814 seconds
Time After: 0.00860 seconds
Memory Before: 557.961 KB
Memory After: 558.969 KB
Time Before: 0.00890 seconds
Time After: 0.00901 seconds
Memory Before: 559.523 KB
Memory After: 560.047 KB
Time Before: 0.00987 seconds
Time After: 0.01300 seconds
Time Taken: 0.00312 seconds
Memory Before: 562.648 KB
Memory After: 563.570 KB
Time Before: 0.00906 seconds
Time After: 0.01738 seconds
Time Taken: 0.00832 seconds
Memory Before: 559.297 KB
Memory After: 1,640.391 KB
Memory Used: 1,081.094 KB
Time Before: 0.02175 seconds
Time After: 0.02221 seconds
Memory Before: 2,135.344 KB
Memory After: 2,135.961 KB
Time Before: 0.02477 seconds
Time After: 0.02605 seconds
Memory Before: 2,147.523 KB
Memory After: 2,147.383 KB
Time Before: 0.02085 seconds
Time After: 0.02636 seconds
Time Taken: 0.00550 seconds
Memory Before: 2,127.523 KB
Memory After: 2,260.734 KB
Memory Used: 133.211 KB
Time Before: 0.03475 seconds
Time After: 0.03490 seconds
Memory Before: 2,814.250 KB
Memory After: 2,814.766 KB
Time Before: 0.04305 seconds
Time After: 0.04427 seconds
Memory Before: 2,902.586 KB
Memory After: 2,903.180 KB
Time Before: 0.05059 seconds
Time After: 0.05077 seconds
Memory Before: 3,539.344 KB
Memory After: 3,539.773 KB
Time Before: 0.05306 seconds
Time After: 0.05463 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.078 KB
Memory After: 3,822.766 KB
UPDATE session SET lastactivity = 1785311940, location = '/forums/private.php?do=newpm&explain=1&u=53176', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.06938 seconds
Time After: 0.06967 seconds
Memory Before: 4,299.531 KB
Memory After: 4,299.742 KB
