Time Before: 0.02585 seconds
Time After: 0.03337 seconds
Time Taken: 0.00752 seconds
Time Before: 0.03346 seconds
Time After: 0.03432 seconds
Time Taken: 0.00086 seconds
Time Before: 0.03462 seconds
Time After: 0.03479 seconds
Time Before: 0.03550 seconds
Time After: 0.03798 seconds
Time Taken: 0.00248 seconds
Time Before: 0.03484 seconds
Time After: 0.04283 seconds
Time Taken: 0.00798 seconds
Time Before: 0.05491 seconds
Time After: 0.05539 seconds
Time Before: 0.05778 seconds
Time After: 0.05897 seconds
Time Before: 0.05422 seconds
Time After: 0.05914 seconds
Time Taken: 0.00492 seconds
Time Before: 0.09997 seconds
Time After: 0.10013 seconds
Time Before: 0.12057 seconds
Time After: 0.12186 seconds
End call of global.php: 0.12371397018433
Time Before: 0.13263 seconds
Time After: 0.13286 seconds
Time Before: 0.13550 seconds
Time After: 0.13695 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=53238', badlocation = 1
Time Before: 0.15659 seconds
Time After: 0.15694 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.15559697151184 seconds with 9 queries, spending 0.008657693862915 doing MySQL queries and 0.14693927764893 doing PHP things.
