Time Before: 0.00831 seconds
Time After: 0.01350 seconds
Time Taken: 0.00520 seconds
Time Before: 0.01362 seconds
Time After: 0.01409 seconds
Time Before: 0.01438 seconds
Time After: 0.01458 seconds
Time Before: 0.01540 seconds
Time After: 0.01802 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01464 seconds
Time After: 0.02203 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02643 seconds
Time After: 0.02680 seconds
Time Before: 0.02926 seconds
Time After: 0.03049 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02578 seconds
Time After: 0.03069 seconds
Time Taken: 0.00492 seconds
Memory After: 2,261.836 KB
Time Before: 0.04367 seconds
Time After: 0.04422 seconds
Time Taken: 0.00056 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06005 seconds
Time After: 0.06135 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.063539981842041
Time Before: 0.06763 seconds
Time After: 0.06788 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.07023 seconds
Time After: 0.07180 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789122372, location = '/forums/private.php?do=newpm&explain=1&u=53366'
Time Before: 0.09028 seconds
Time After: 0.09065 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.089194059371948 seconds with 9 queries, spending 0.0089235305786133 doing MySQL queries and 0.080270528793335 doing PHP things.
