Time Before: 0.03664 seconds
Time After: 0.04278 seconds
Time Taken: 0.00614 seconds
Time Before: 0.04285 seconds
Time After: 0.04336 seconds
Time Before: 0.04362 seconds
Time After: 0.04374 seconds
Time Before: 0.04455 seconds
Time After: 0.04725 seconds
Time Taken: 0.00270 seconds
Time Before: 0.04382 seconds
Time After: 0.05141 seconds
Time Taken: 0.00759 seconds
Time Before: 0.06067 seconds
Time After: 0.06117 seconds
Time Before: 0.06247 seconds
Time After: 0.06377 seconds
Time Before: 0.05981 seconds
Time After: 0.06396 seconds
Time Taken: 0.00415 seconds
Time Before: 0.10726 seconds
Time After: 0.10741 seconds
Time Before: 0.12598 seconds
Time After: 0.12725 seconds
End call of global.php: 0.12950491905212
Time Before: 0.13685 seconds
Time After: 0.13708 seconds
Time Before: 0.13967 seconds
Time After: 0.14108 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=5339'
Time Before: 0.15835 seconds
Time After: 0.15860 seconds
Memory Before: 4,287.719 KB
Memory After: 4,287.969 KB
Memory Used: 0.250 KB
Page generated in 0.15704989433289 seconds with 9 queries, spending 0.0084450244903564 doing MySQL queries and 0.14860486984253 doing PHP things.
