Time Before: 0.01770 seconds
Time After: 0.02640 seconds
Time Taken: 0.00870 seconds
Time Before: 0.02651 seconds
Time After: 0.02696 seconds
Time Before: 0.02720 seconds
Time After: 0.02732 seconds
Time Before: 0.02813 seconds
Time After: 0.03134 seconds
Time Taken: 0.00321 seconds
Time Before: 0.02740 seconds
Time After: 0.03610 seconds
Time Before: 0.04923 seconds
Time After: 0.04950 seconds
Time Before: 0.05181 seconds
Time After: 0.05412 seconds
Time Taken: 0.00231 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04848 seconds
Time After: 0.05435 seconds
Time Taken: 0.00587 seconds
Memory After: 2,261.836 KB
Time Before: 0.08571 seconds
Time After: 0.08582 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.10550 seconds
Time After: 0.10680 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.10924792289734
Time Before: 0.11631 seconds
Time After: 0.11645 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11875 seconds
Time After: 0.12016 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788945413, location = '/forums/private.php?do=newpm&explain=1&u=53419'
Time Before: 0.14050 seconds
Time After: 0.14076 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.13908505439758 seconds with 9 queries, spending 0.009580135345459 doing MySQL queries and 0.12950491905212 doing PHP things.
