Time Before: 0.00214 seconds
Time After: 0.00285 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00295 seconds
Time After: 0.00367 seconds
Time Before: 0.00424 seconds
Time After: 0.00442 seconds
Time Before: 0.00527 seconds
Time After: 0.00774 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00453 seconds
Time After: 0.01124 seconds
Time Taken: 0.00671 seconds
Time Before: 0.01309 seconds
Time After: 0.01345 seconds
Time Before: 0.01640 seconds
Time After: 0.01770 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01249 seconds
Time After: 0.01796 seconds
Time Taken: 0.00546 seconds
Memory After: 2,261.719 KB
Time Before: 0.02496 seconds
Time After: 0.02522 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02735 seconds
Time After: 0.02901 seconds
Time Taken: 0.00167 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.03172 seconds
Time After: 0.03190 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03406 seconds
Time After: 0.03593 seconds
Time Taken: 0.00187 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=5346', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04884 seconds
Time After: 0.04933 seconds
Memory Before: 4,287.508 KB
Memory After: 4,287.734 KB
