Time Before: 0.00133 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00241 seconds
Time Before: 0.00266 seconds
Time After: 0.00276 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00335 seconds
Time After: 0.00537 seconds
Time Taken: 0.00202 seconds
Time Before: 0.00281 seconds
Time After: 0.00892 seconds
Time Taken: 0.00611 seconds
Time Before: 0.01077 seconds
Time After: 0.01112 seconds
Time Before: 0.01348 seconds
Time After: 0.01462 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01010 seconds
Time After: 0.01479 seconds
Time Taken: 0.00469 seconds
Time Before: 0.01968 seconds
Time After: 0.01978 seconds
Memory Before: 3,438.367 KB
Memory After: 3,438.883 KB
Time Before: 0.02143 seconds
Time After: 0.02268 seconds
End call of global.php: 0.024332046508789
Time Before: 0.02528 seconds
Time After: 0.02540 seconds
Time Before: 0.02723 seconds
Time After: 0.02867 seconds
SET lastactivity = 1788923077, location = '/forums/private.php?do=newpm&explain=1&u=535'
Time Before: 0.04129 seconds
Time After: 0.25822 seconds
Time Taken: 0.21694 seconds
Memory Before: 4,911.117 KB
Memory After: 4,911.336 KB
Page generated in 0.04035496711731 seconds with 9 queries, spending 0.22397780418396 doing MySQL queries and -0.18362283706665 doing PHP things.
