Time Before: 0.00135 seconds
Time After: 0.00185 seconds
Time Before: 0.00191 seconds
Time After: 0.00225 seconds
Time Before: 0.00248 seconds
Time After: 0.00260 seconds
Time Before: 0.00329 seconds
Time After: 0.00581 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00265 seconds
Time After: 0.01042 seconds
Time Taken: 0.00777 seconds
Time Before: 0.01221 seconds
Time After: 0.01265 seconds
Time Before: 0.01523 seconds
Time After: 0.01638 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01163 seconds
Time After: 0.01656 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02179 seconds
Time After: 0.02191 seconds
Time Before: 0.02377 seconds
Time After: 0.02497 seconds
End call of global.php: 0.026675939559937
Time Before: 0.02807 seconds
Time After: 0.02832 seconds
Time Before: 0.03057 seconds
Time After: 0.03205 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=53525', badlocation = 1
Time Before: 0.04467 seconds
Time After: 0.05040 seconds
Time Taken: 0.00572 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.043731927871704 seconds with 9 queries, spending 0.013347625732422 doing MySQL queries and 0.030384302139282 doing PHP things.
