Time Before: 0.01452 seconds
Time After: 0.01934 seconds
Time Taken: 0.00482 seconds
Time Before: 0.01944 seconds
Time After: 0.01992 seconds
Time Before: 0.02015 seconds
Time After: 0.02029 seconds
Time Before: 0.02120 seconds
Time After: 0.02345 seconds
Time Taken: 0.00225 seconds
Time Before: 0.02036 seconds
Time After: 0.02773 seconds
Time Taken: 0.00737 seconds
Time Before: 0.03363 seconds
Time After: 0.03410 seconds
Time Before: 0.03729 seconds
Time After: 0.03853 seconds
Time Before: 0.03302 seconds
Time After: 0.03886 seconds
Time Taken: 0.00584 seconds
Time Before: 0.06145 seconds
Time After: 0.06158 seconds
Time Before: 0.07290 seconds
Time After: 0.07414 seconds
End call of global.php: 0.076172113418579
Time Before: 0.08158 seconds
Time After: 0.08180 seconds
Time Before: 0.08490 seconds
Time After: 0.08643 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=53614', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.10435 seconds
Time After: 0.10489 seconds
Time Taken: 0.00054 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.10304713249207 seconds with 9 queries, spending 0.0082502365112305 doing MySQL queries and 0.094796895980835 doing PHP things.
