Time Before: 0.00152 seconds
Time After: 0.00211 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00221 seconds
Time After: 0.00279 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00310 seconds
Time After: 0.00328 seconds
Time Before: 0.00404 seconds
Time After: 0.00615 seconds
Time Taken: 0.00211 seconds
Time Before: 0.00336 seconds
Time After: 0.01073 seconds
Time Taken: 0.00737 seconds
Time Before: 0.01252 seconds
Time After: 0.01286 seconds
Time Before: 0.01520 seconds
Time After: 0.01636 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01197 seconds
Time After: 0.01655 seconds
Time Taken: 0.00459 seconds
Time Before: 0.02144 seconds
Time After: 0.02159 seconds
Time Before: 0.02333 seconds
Time After: 0.02454 seconds
End call of global.php: 0.02620005607605
Time Before: 0.02746 seconds
Time After: 0.02761 seconds
Time Before: 0.02962 seconds
Time After: 0.03105 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=5366'
Time Before: 0.04925 seconds
Time After: 0.04959 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
Page generated in 0.04829216003418 seconds with 9 queries, spending 0.0076515674591064 doing MySQL queries and 0.040640592575073 doing PHP things.
