Time Before: 0.00861 seconds
Time After: 0.01091 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01098 seconds
Time After: 0.01136 seconds
Time Before: 0.01159 seconds
Time After: 0.01173 seconds
Time Before: 0.01276 seconds
Time After: 0.01543 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01181 seconds
Time After: 0.01989 seconds
Time Taken: 0.00808 seconds
Time Before: 0.02566 seconds
Time After: 0.02604 seconds
Time Before: 0.02872 seconds
Time After: 0.02989 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02504 seconds
Time After: 0.03011 seconds
Time Taken: 0.00507 seconds
Memory After: 2,261.719 KB
Time Before: 0.04665 seconds
Time After: 0.04684 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.05755 seconds
Time After: 0.05877 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.060976982116699
Time Before: 0.06678 seconds
Time After: 0.06693 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.06949 seconds
Time After: 0.07094 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=53731'
Time Before: 0.08925 seconds
Time After: 0.08962 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.088119029998779 seconds with 9 queries, spending 0.0080997943878174 doing MySQL queries and 0.080019235610962 doing PHP things.
