Time Before: 0.01978 seconds
Time After: 0.02591 seconds
Time Taken: 0.00613 seconds
Time Before: 0.02602 seconds
Time After: 0.02662 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02690 seconds
Time After: 0.02710 seconds
Time Before: 0.02809 seconds
Time After: 0.03206 seconds
Time Taken: 0.00397 seconds
Time Before: 0.02717 seconds
Time After: 0.03661 seconds
Time Taken: 0.00944 seconds
Time Before: 0.04343 seconds
Time After: 0.04375 seconds
Time Before: 0.04505 seconds
Time After: 0.04627 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04250 seconds
Time After: 0.04646 seconds
Time Taken: 0.00396 seconds
Memory After: 2,261.719 KB
Time Before: 0.08957 seconds
Time After: 0.08977 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10984 seconds
Time After: 0.11114 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.12239 seconds
Time After: 0.12261 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12528 seconds
Time After: 0.12673 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=53767' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14644 seconds
Time After: 0.14676 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
