Time Before: 0.01914 seconds
Time After: 0.02487 seconds
Time Taken: 0.00573 seconds
Time Before: 0.02495 seconds
Time After: 0.02542 seconds
Time Before: 0.02568 seconds
Time After: 0.02584 seconds
Time Before: 0.02670 seconds
Time After: 0.02889 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02591 seconds
Time After: 0.03347 seconds
Time Taken: 0.00756 seconds
Time Before: 0.03954 seconds
Time After: 0.04001 seconds
Time Before: 0.04349 seconds
Time After: 0.04471 seconds
Time Before: 0.03875 seconds
Time After: 0.04490 seconds
Time Taken: 0.00614 seconds
Time Before: 0.07913 seconds
Time After: 0.07930 seconds
Time Before: 0.09176 seconds
Time After: 0.09303 seconds
End call of global.php: 0.095057964324951
Time Before: 0.10179 seconds
Time After: 0.10195 seconds
Time Before: 0.10470 seconds
Time After: 0.10663 seconds
Time Taken: 0.00193 seconds
SET lastactivity = 1788909230, location = '/forums/private.php?do=newpm&explain=1&u=53791', badlocation = 1
Time Before: 0.12455 seconds
Time After: 0.12483 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.12337493896484 seconds with 9 queries, spending 0.008331298828125 doing MySQL queries and 0.11504364013672 doing PHP things.
