Time Before: 0.01029 seconds
Time After: 0.01297 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01305 seconds
Time After: 0.01356 seconds
Time Before: 0.01381 seconds
Time After: 0.01397 seconds
Time Before: 0.01521 seconds
Time After: 0.01768 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01403 seconds
Time After: 0.02115 seconds
Time Taken: 0.00712 seconds
Time Before: 0.02437 seconds
Time After: 0.02479 seconds
Time Before: 0.02742 seconds
Time After: 0.02867 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02367 seconds
Time After: 0.02885 seconds
Time Taken: 0.00518 seconds
Memory After: 2,261.836 KB
Time Before: 0.04650 seconds
Time After: 0.04667 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05644 seconds
Time After: 0.05769 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.059779167175293
Time Before: 0.06386 seconds
Time After: 0.06402 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06645 seconds
Time After: 0.06839 seconds
Time Taken: 0.00194 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788908581, location = '/forums/private.php?do=newpm&explain=1&u=53809'
Time Before: 0.08549 seconds
Time After: 0.09806 seconds
Time Taken: 0.01257 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.084380149841309 seconds with 9 queries, spending 0.020885944366455 doing MySQL queries and 0.063494205474854 doing PHP things.
