Time Before: 0.00238 seconds
Time After: 0.00291 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00298 seconds
Time After: 0.00336 seconds
Time Before: 0.00359 seconds
Time After: 0.00375 seconds
Time Before: 0.00441 seconds
Time After: 0.00659 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00379 seconds
Time After: 0.01034 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01229 seconds
Time After: 0.01277 seconds
Time Before: 0.01578 seconds
Time After: 0.01700 seconds
Time Before: 0.01157 seconds
Time After: 0.01728 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02448 seconds
Time After: 0.02461 seconds
Time Before: 0.02652 seconds
Time After: 0.02774 seconds
Time Before: 0.03099 seconds
Time After: 0.03114 seconds
Time Before: 0.03357 seconds
Time After: 0.03501 seconds
UPDATE session SET lastactivity = 1782979973, location = '/forums/private.php?do=newpm&explain=1&u=53818', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05047 seconds
Time After: 0.05076 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
