Time Before: 0.00136 seconds
Time After: 0.00190 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00200 seconds
Time After: 0.00251 seconds
Time Before: 0.00273 seconds
Time After: 0.00285 seconds
Time Before: 0.00357 seconds
Time After: 0.00591 seconds
Time Taken: 0.00234 seconds
Time Before: 0.00290 seconds
Time After: 0.01101 seconds
Time Taken: 0.00811 seconds
Time Before: 0.01305 seconds
Time After: 0.01347 seconds
Time Before: 0.01604 seconds
Time After: 0.01721 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01233 seconds
Time After: 0.01738 seconds
Time Taken: 0.00505 seconds
Time Before: 0.02238 seconds
Time After: 0.02253 seconds
Time Before: 0.02448 seconds
Time After: 0.02573 seconds
Time Before: 0.02969 seconds
Time After: 0.02987 seconds
Time Before: 0.03185 seconds
Time After: 0.03330 seconds
UPDATE session SET lastactivity = 1783157300, location = '/forums/private.php?do=newpm&explain=1&u=53888' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04607 seconds
Time After: 0.04648 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
