Time Before: 0.02526 seconds
Time After: 0.03388 seconds
Time Taken: 0.00863 seconds
Time Before: 0.03400 seconds
Time After: 0.03438 seconds
Time Before: 0.03496 seconds
Time After: 0.03535 seconds
Time Before: 0.03613 seconds
Time After: 0.03828 seconds
Time Taken: 0.00215 seconds
Time Before: 0.03540 seconds
Time After: 0.04392 seconds
Time Taken: 0.00853 seconds
Time Before: 0.05159 seconds
Time After: 0.05199 seconds
Time Before: 0.05482 seconds
Time After: 0.05635 seconds
Time Taken: 0.00153 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05079 seconds
Time After: 0.05660 seconds
Time Taken: 0.00581 seconds
Memory After: 2,261.719 KB
Time Before: 0.10333 seconds
Time After: 0.10350 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.13248 seconds
Time After: 0.13372 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.13578510284424
Time Before: 0.14355 seconds
Time After: 0.14381 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.14712 seconds
Time After: 0.14866 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=53902'
Time Before: 0.17097 seconds
Time After: 0.17131 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.16978216171265 seconds with 9 queries, spending 0.0083961486816406 doing MySQL queries and 0.16138601303101 doing PHP things.
