Time Before: 0.00231 seconds
Time After: 0.00294 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00305 seconds
Time After: 0.00347 seconds
Time Before: 0.00374 seconds
Time After: 0.00388 seconds
Time Before: 0.00480 seconds
Time After: 0.00783 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00396 seconds
Time After: 0.01161 seconds
Time Taken: 0.00764 seconds
Time Before: 0.01438 seconds
Time After: 0.01480 seconds
Time Before: 0.01746 seconds
Time After: 0.01865 seconds
Time Before: 0.01361 seconds
Time After: 0.01892 seconds
Time Taken: 0.00531 seconds
Time Before: 0.02634 seconds
Time After: 0.02648 seconds
Time Before: 0.02943 seconds
Time After: 0.03128 seconds
Time Taken: 0.00185 seconds
Time Before: 0.03511 seconds
Time After: 0.03526 seconds
Time Before: 0.03739 seconds
Time After: 0.03882 seconds
UPDATE session SET lastactivity = 1776700627, location = '/forums/private.php?do=newpm&explain=1&u=53935', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05332 seconds
Time After: 0.05362 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
