Time Before: 0.00141 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00246 seconds
Time Before: 0.00272 seconds
Time After: 0.00288 seconds
Time Before: 0.00353 seconds
Time After: 0.00593 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00293 seconds
Time After: 0.00931 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01113 seconds
Time After: 0.01153 seconds
Time Before: 0.01392 seconds
Time After: 0.01514 seconds
Time Before: 0.01052 seconds
Time After: 0.01531 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02058 seconds
Time After: 0.02073 seconds
Time Before: 0.02258 seconds
Time After: 0.02379 seconds
End call of global.php: 0.025454044342041
Time Before: 0.02668 seconds
Time After: 0.02684 seconds
Time Before: 0.02890 seconds
Time After: 0.03032 seconds
SET lastactivity = 1789104348, location = '/forums/private.php?do=newpm&explain=1&u=53961'
Time Before: 0.04292 seconds
Time After: 0.04319 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.041953086853027 seconds with 9 queries, spending 0.0078878402709961 doing MySQL queries and 0.034065246582031 doing PHP things.
