Time Before: 0.01515 seconds
Time After: 0.02060 seconds
Time Taken: 0.00544 seconds
Time Before: 0.02069 seconds
Time After: 0.02115 seconds
Time Before: 0.02143 seconds
Time After: 0.02156 seconds
Time Before: 0.02241 seconds
Time After: 0.02477 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02164 seconds
Time After: 0.02916 seconds
Time Taken: 0.00752 seconds
Time Before: 0.03509 seconds
Time After: 0.03554 seconds
Time Before: 0.03894 seconds
Time After: 0.04039 seconds
Time Before: 0.03441 seconds
Time After: 0.04060 seconds
Time Taken: 0.00619 seconds
Time Before: 0.07197 seconds
Time After: 0.07212 seconds
Time Before: 0.08483 seconds
Time After: 0.08608 seconds
Time Before: 0.09976 seconds
Time After: 0.09991 seconds
Time Before: 0.10262 seconds
Time After: 0.10406 seconds
UPDATE session SET lastactivity = 1769251740, location = '/forums/private.php?do=newpm&explain=1&u=54009', badlocation = 1 WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.12124 seconds
Time After: 0.12155 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
