Time Before: 0.00968 seconds
Time After: 0.01223 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01231 seconds
Time After: 0.01267 seconds
Time Before: 0.01290 seconds
Time After: 0.01303 seconds
Time Before: 0.01391 seconds
Time After: 0.01688 seconds
Time Taken: 0.00297 seconds
Time Before: 0.01311 seconds
Time After: 0.02248 seconds
Time Taken: 0.00938 seconds
Time Before: 0.02619 seconds
Time After: 0.02662 seconds
Time Before: 0.02909 seconds
Time After: 0.03033 seconds
Time Before: 0.02538 seconds
Time After: 0.03054 seconds
Time Taken: 0.00516 seconds
Time Before: 0.04852 seconds
Time After: 0.04869 seconds
Time Before: 0.05662 seconds
Time After: 0.05784 seconds
End call of global.php: 0.059886932373047
Time Before: 0.06267 seconds
Time After: 0.06285 seconds
Time Before: 0.06610 seconds
Time After: 0.06754 seconds
SET lastactivity = 1776573223, location = '/forums/private.php?do=newpm&explain=1&u=54069'
Time Before: 0.08460 seconds
Time After: 0.08495 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.083537101745605 seconds with 9 queries, spending 0.0085082054138184 doing MySQL queries and 0.075028896331787 doing PHP things.
