Time Before: 0.00188 seconds
Time After: 0.00239 seconds
Time Before: 0.00249 seconds
Time After: 0.00296 seconds
Time Before: 0.00318 seconds
Time After: 0.00331 seconds
Time Before: 0.00403 seconds
Time After: 0.00745 seconds
Time Taken: 0.00342 seconds
Time Before: 0.00336 seconds
Time After: 0.01084 seconds
Time Taken: 0.00748 seconds
Time Before: 0.01259 seconds
Time After: 0.01304 seconds
Time Before: 0.01654 seconds
Time After: 0.01782 seconds
Time Before: 0.01199 seconds
Time After: 0.01806 seconds
Time Taken: 0.00607 seconds
Time Before: 0.02449 seconds
Time After: 0.02464 seconds
Time Before: 0.02696 seconds
Time After: 0.02824 seconds
Time Before: 0.03195 seconds
Time After: 0.03211 seconds
Time Before: 0.03513 seconds
Time After: 0.03658 seconds
UPDATE session SET lastactivity = 1785365417, location = '/forums/private.php?do=newpm&explain=1&u=54072', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04899 seconds
Time After: 0.04932 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
