Time Before: 0.00228 seconds
Time After: 0.00276 seconds
Time Before: 0.00284 seconds
Time After: 0.00322 seconds
Time Before: 0.00344 seconds
Time After: 0.00359 seconds
Time Before: 0.00449 seconds
Time After: 0.00675 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00366 seconds
Time After: 0.01150 seconds
Time Taken: 0.00784 seconds
Time Before: 0.01411 seconds
Time After: 0.01497 seconds
Time Taken: 0.00086 seconds
Time Before: 0.01831 seconds
Time After: 0.01951 seconds
Time Before: 0.01302 seconds
Time After: 0.01968 seconds
Time Taken: 0.00667 seconds
Time Before: 0.02631 seconds
Time After: 0.02661 seconds
Time Before: 0.02912 seconds
Time After: 0.03038 seconds
End call of global.php: 0.032013893127441
Time Before: 0.03415 seconds
Time After: 0.03463 seconds
Time Before: 0.03719 seconds
Time After: 0.03872 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1788969259, location = '/forums/private.php?do=newpm&explain=1&u=54237'
Time Before: 0.05127 seconds
Time After: 0.05158 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.050348997116089 seconds with 9 queries, spending 0.0087246894836426 doing MySQL queries and 0.041624307632446 doing PHP things.
