Time Before: 0.01858 seconds
Time After: 0.02469 seconds
Time Taken: 0.00611 seconds
Time Before: 0.02479 seconds
Time After: 0.02520 seconds
Time Before: 0.02541 seconds
Time After: 0.02556 seconds
Time Before: 0.02638 seconds
Time After: 0.03005 seconds
Time Taken: 0.00367 seconds
Time Before: 0.02563 seconds
Time After: 0.03433 seconds
Time Taken: 0.00870 seconds
Time Before: 0.04195 seconds
Time After: 0.04236 seconds
Time Before: 0.04484 seconds
Time After: 0.04612 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04120 seconds
Time After: 0.04632 seconds
Time Taken: 0.00512 seconds
Memory After: 2,261.836 KB
Time Before: 0.06965 seconds
Time After: 0.06978 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.43208 seconds
Time After: 0.43337 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.43640208244324
Time Before: 0.44529 seconds
Time After: 0.44557 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.44809 seconds
Time After: 0.44955 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788973216, location = '/forums/private.php?do=newpm&explain=1&u=54311', badlocation = 1
Time Before: 0.46951 seconds
Time After: 0.46979 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.4683039188385 seconds with 9 queries, spending 0.0093564987182617 doing MySQL queries and 0.45894742012024 doing PHP things.
