Time Before: 0.02674 seconds
Time After: 0.03676 seconds
Time Taken: 0.01002 seconds
Time Before: 0.03684 seconds
Time After: 0.03725 seconds
Time Before: 0.03750 seconds
Time After: 0.03764 seconds
Time Before: 0.03855 seconds
Time After: 0.04058 seconds
Time Taken: 0.00203 seconds
Time Before: 0.03771 seconds
Time After: 0.04489 seconds
Time Taken: 0.00718 seconds
Time Before: 0.05710 seconds
Time After: 0.05751 seconds
Time Before: 0.05893 seconds
Time After: 0.06036 seconds
Time Before: 0.05645 seconds
Time After: 0.06058 seconds
Time Taken: 0.00412 seconds
Time Before: 0.09708 seconds
Time After: 0.09722 seconds
Time Before: 0.11277 seconds
Time After: 0.11400 seconds
End call of global.php: 0.11614084243774
Time Before: 0.12461 seconds
Time After: 0.12478 seconds
Time Before: 0.12767 seconds
Time After: 0.12913 seconds
SET lastactivity = 1776689684, location = '/forums/private.php?do=newpm&explain=1&u=54342'
Time Before: 0.14446 seconds
Time After: 0.14477 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.1434018611908 seconds with 9 queries, spending 0.0077347755432129 doing MySQL queries and 0.13566708564758 doing PHP things.
