Time Before: 0.00901 seconds
Time After: 0.01210 seconds
Time Taken: 0.00310 seconds
Time Before: 0.01219 seconds
Time After: 0.01255 seconds
Time Before: 0.01275 seconds
Time After: 0.01286 seconds
Time Before: 0.01363 seconds
Time After: 0.01585 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01293 seconds
Time After: 0.02007 seconds
Time Taken: 0.00714 seconds
Time Before: 0.02414 seconds
Time After: 0.02450 seconds
Time Before: 0.02704 seconds
Time After: 0.02826 seconds
Time Before: 0.02353 seconds
Time After: 0.02844 seconds
Time Taken: 0.00492 seconds
Time Before: 0.04619 seconds
Time After: 0.04632 seconds
Time Before: 0.05427 seconds
Time After: 0.05552 seconds
End call of global.php: 0.057512044906616
Time Before: 0.06123 seconds
Time After: 0.06139 seconds
Time Before: 0.06351 seconds
Time After: 0.06491 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=54369', badlocation = 1
Time Before: 0.08054 seconds
Time After: 0.08083 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.079612970352173 seconds with 9 queries, spending 0.0075104236602783 doing MySQL queries and 0.072102546691895 doing PHP things.
