Time Before: 0.02090 seconds
Time After: 0.02956 seconds
Time Taken: 0.00866 seconds
Time Before: 0.02965 seconds
Time After: 0.02996 seconds
Time Before: 0.03019 seconds
Time After: 0.03032 seconds
Time Before: 0.03099 seconds
Time After: 0.03289 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03039 seconds
Time After: 0.03733 seconds
Time Taken: 0.00695 seconds
Time Before: 0.04964 seconds
Time After: 0.04996 seconds
Time Before: 0.05193 seconds
Time After: 0.05311 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04894 seconds
Time After: 0.05332 seconds
Time Taken: 0.00438 seconds
Memory After: 2,261.836 KB
Time Before: 0.08365 seconds
Time After: 0.08393 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.36420 seconds
Time After: 0.36595 seconds
Time Taken: 0.00175 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.37633 seconds
Time After: 0.37647 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.37890 seconds
Time After: 0.38038 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788960627, location = '/forums/private.php?do=newpm&explain=1&u=54397', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.40171 seconds
Time After: 0.40199 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
