Time Before: 0.01519 seconds
Time After: 0.01914 seconds
Time Taken: 0.00395 seconds
Time Before: 0.01921 seconds
Time After: 0.01966 seconds
Time Before: 0.01993 seconds
Time After: 0.02010 seconds
Time Before: 0.02097 seconds
Time After: 0.02339 seconds
Time Taken: 0.00242 seconds
Time Before: 0.02017 seconds
Time After: 0.02824 seconds
Time Taken: 0.00806 seconds
Time Before: 0.03460 seconds
Time After: 0.03497 seconds
Time Before: 0.03775 seconds
Time After: 0.03900 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03379 seconds
Time After: 0.03924 seconds
Time Taken: 0.00545 seconds
Memory After: 2,261.719 KB
Time Before: 0.06535 seconds
Time After: 0.06551 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.07708 seconds
Time After: 0.07833 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.08585 seconds
Time After: 0.08610 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08914 seconds
Time After: 0.09060 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=54461', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.10815 seconds
Time After: 0.10843 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
